Air conditioning: How can you tell if all the R-12 has leaked out?
Old Jul 1, 2001 | 01:05 AM
RadAV8R's Avatar
How could you tell if it all leaked out without running it? I tried opening the capped valve on the silver can, but no pressure came out. Is that even on the right track? Does the car have to be running for it to have any pressure?
The reason I am asking is because I am pulling the engine to transplant after the car was damaged significantly in the right front due to collision. Battery box area was hit hard and the radiator & AC condenser were pushed more toward the driver side. The entire AC system doesn't appear to have taken much damage however. The condenser is a little bent overall, as well as a few of the lines, but seems intact. Can you remove the whole system in one piece without opening it up? I guess it would be easier to just start ripping those AC components out, but with all the warning labels i've been wondering if it's safe to do? Is it dangerous to breathe that stuff?
If you can't remove the system intact how do you go about disassembling it (assuming there is still pressure in it)? Many thanks to anyone who can offer help or has even taken time to read this!
Old Jul 1, 2001 | 02:30 AM
Dan88Iroc's Avatar
The only advice that I can give you is about how to check if it has leaked out. I heard from a fried that you should be able to check with a black light. Of course this needs to be done when it is dark.
88 Iroc, 305 TPI, Hypertech chip, K&N's, Airfoil, Flowmaster American Thunder, High-Flow cat, 160 therm. Bosch Platinum +4's, American Racing Rims, Partially gutted airboxes, removed screens from MAF sensor, more mods soon.
Old Jul 1, 2001 | 02:33 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If you press the shreader valve in line and nothing comes out, its empty.
The blacklight thing only works when there is a dye in the system.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 01, 2001).]
Old Jul 2, 2001 | 11:11 AM
RadAV8R's Avatar
Thanks guys...double checked the valves and nothing comes out... going to try taking it all apart this evening.
specialized
Jun 18, 2022 09:26 AM
ramicio
Sep 6, 2015 11:25 AM
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
drathaar907
Aug 6, 2015 04:20 PM
