Rings
Old Jun 30, 2001 | 03:43 PM
MurphsIroc's Avatar
Rings
If I have bad rings, would the car smoke all the time? And how bad would the smoke be? I really need to know before this week. Thanks guys
Old Jun 30, 2001 | 05:21 PM
MurphsIroc's Avatar
ttt Please help
Old Jun 30, 2001 | 05:44 PM
Guest
Guest
Posts: n/a
Yea it would, but a badly worn valve stem can do that too. The amount of smoke varies, and is generally worse as the rpm's climb.
Old Jul 1, 2001 | 09:59 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
it also depends on how thick the oil you use is. Run a compression test.
Old Jul 1, 2001 | 01:19 PM
MurphsIroc's Avatar
I use 10-w40 motor oil.... Is that too thick? Or is it good. I need a little more help here. Please
Old Jul 1, 2001 | 02:22 PM
MurphsIroc's Avatar
PLEASE HELP
Old Jul 2, 2001 | 04:30 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
for NJ. No you can't get much thicker and be safe. I am afraid you can't tell more without a compression test or leak down test. They will tell you if you need rings or just a valve job. If it smokes all the time at idle, its probably rings. If it is really bad after it has been ideling for a while and you press the accelerator, its probably valve guides and seals.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
