should my engine die if...
Old Feb 20, 2005 | 08:17 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I push down the lever on my tps sensor without pushing opening my throttle body ?
87 IROC Z, L98 350 TPI..etc..
Better yet, when I actually disconnect my TPS sensor, should the car die ?
The reason I ask is because I vaguely remember that these actions were common of TPS sensors, and currently, I could disconnect my TPS sensor with the motor running and it does not flinch. Nor does it flinch when I push its lever down without opening the throttle body. All indications would indicate that the TPS sensor was bad. I know they are deathly expensive, but is their a way to test it ?
Old Feb 20, 2005 | 09:12 PM
orangetang's Avatar
Car: 91 Firebird Green
Engine: SBC L03 - TBI 5.0L V8
Transmission: WC T5
Someone might have better advice, but I just replaced my TPS, so....
When my TPS failed, it was sending a 2.6V signal to the computer while at an idle. The idle was high, rich and fluctuated in RPM. If I unplugged the TPS, the engine didnt' seem to run much different at all. Are you getting a Service Engine light? I'd just take it to a friend or to a shop for a diagnostics scan... And as far as TPS prices go, an 87 TPI should be about $120CAD... That's not too bad is it?
Old Feb 22, 2005 | 03:24 AM
Car: 1987 IROC Z
are we talking about the same part? I've replaced the TPS sensor before and it was only about $30 bux I think. It was even an adjustable TPS sensor. My car does not react to it being plugged or unplugged anymore. It did at one time prior to all of my modifications. I guess that would be a good indicator that its dead.
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
