possible dist. 1 tooth off?
Old Jul 3, 2001 | 04:05 PM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
ok I installed a new cam, and intake set my timing to were the car said to (at 0) with est disconnected, car runs fine, but surges at idle with tranny in gear after all warmed up, and wants to die, and when it does die it hotstarts like its overadvanced, and when I advance it (even just 2 degrees) I notice more power but it detonates bad, and hotstarts bad. When its set at 0 its doesnt hotstart as bad, but feels really slow. So whats your opinion on this, possibly just a tooth off on the distributor? I noticed when i put it all back together the rotor was a little off from the plug in the cap, and the marks was at o TDC when i put in the dist.
"If its in my way-It gets run over"
--'91 firebird
305 TBI
Hypertech chip
Edelbrock performer intake
Crane compucam 2010
B&M shift kit
straight pipe exhaust
Old Jul 3, 2001 | 04:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you are setting your timing with a timing light, then one or 10 teeth off isn't going to make a difference on how it runs. If you are doing it "static", or setting it by marks you made before taking it apart, that's a different story. But, one tooth is a whole bunch more than 2 degrees.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
pjsparts
Oct 29, 2025 06:39 PM
gord327
Oct 3, 2015 01:25 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
dimented24x7
Sep 17, 2015 06:58 AM
