Popping Sounds in Engine!
Old Feb 20, 2005 | 10:29 PM
bandit_knight81's Avatar
Car: 1982 Pontiac Trans Am
Engine: 350ci/5.7ltr ('78 Camaro)
Hello, yeah it's me again. I'm still having trouble with my car.
This time my engine is making popping sounds when I drive. At first I thought that the idle wasn't adjusted correctly. I adjusted it and took it out for a spin. Everything was fine until I accelerated up to about 70mph. As soon as I decelerated and accelerated again that’s when the popping sounds happened again. It felt like I was losing power and could hardly accelerate at all. To make matters worse my car stalled and I barely managed to start it up again and make home.
From there, I took out my sparkplugs and there were filthy! Black, covered in carbons. I cleaned them, gapped them and re-inserted them correctly. I checked the carburetor for leaks and adjusted the float level. Everything was correct. I started the car up and it was running well, until I punched it up to 70 again.
I took off the valve covers and looked at the valves and springs. With the help of Stephen 87 IROC, Aperion, and ede. I managed to check the springs and valves but they were fine as well and did not require any additional adjustments. So that leaves me back at square one.
Could it be the carburetor itself that is need of cleaning or replacement? What is making that popping sound every time I accelerate? Could it be some other part that needs to be cleaned or replaced? As usual if anyone has any input, I would greatly appreciate the help.
My information about the car is:
V8 305ci (5.0l)
Automatic Transmission
Thank you,
the bandit_knight81
Old Feb 20, 2005 | 10:41 PM
brutalform's Avatar
I had a purge valve cause a pop one time on another GM vehicle. Also make sure there is no cracks in the plug porcelins.
Old Feb 21, 2005 | 12:06 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
popping when you let off the gas? this is an easy one...
you're either running lean, or your timing is off, or you have an exhaust leak.
I had this happen when I installed headers and I went through hell finding out the problem.
it's simple.
Old Feb 21, 2005 | 01:38 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
your cat could be clogged, i had similar power loss when i had my cats clogged, just bought new ones and it ran fine.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
