180 thermostat
Old Jul 3, 2001 | 02:49 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
180 thermostat
what is the temp for a stock thermostat? is a 180 thermostat going to do much for the temperature in my combustion chamber? should i go lower then a 180, and if i do will it hinder the operations of my smog equipment? thanks-
1987 z28 305 4 barrel
Old Jul 3, 2001 | 08:22 AM
irocbsa's Avatar
170 is usually the lowest you should go on a stock engine/PROM. Lower than that and you usually start getting into driveability problems. Just ask the PROM burning guys about that. The lower thermo should help to lower temps a bit but if you have some other cooling problem, such as a water pump on the fritz, then it will do no good at all. It will not affect your emissions equipment to go to a lower temp thermo but remember that GM designed these cars to run really hot in order to keep emissions down but in turn caused the engine components to wear faster. If your engine is in proper working order you should have no problem passing smog tests, provided you have them. I have a 180 in my car. BTW, the stock thermo temp is 190.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 3, 2001 | 08:27 PM
Guest
Guest
Posts: n/a
A 180 is probably the best choice. If you have an electric fan (im not sure) then you will have to do something to get it to turn on sooner, otherwise it will heat up in traffic anyway.
I wouldnt worry about smog if the car is in tune, a 180 wont affect it if its running right.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Dragonsys
Sep 25, 2015 03:51 PM
Stryker412
Sep 20, 2015 06:59 PM
