Getting rid of AIR have a q.
Old Jul 1, 2001 | 11:58 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I am going to remove my AIR system since I dont need it anymore. I am planning on keeping it just in case.
Well my question is this...I have the stock exhaust manifolds in with the tubes coming off of them. What would be a good way to seal those holes up. My friend suggested to use plan old bolts. Would that work or no and if so is there anyone that has done it and know what size bolts they are? I am pretty sure that is all I need but if there is anything you guys think I should do just let me know. Thanks for the help.
"I'm not dumb, I just have an amazing command of thoroughly useless
information."
Bill Waterson creator of Calvin & Hobbes.
Old Jul 2, 2001 | 01:19 AM
ArnoldBraker's Avatar
I just removed mine. I still need to find a way to get the pipe that goes around the back of the engine though. I used a brass plug to seal up the holes and wrapped them in teflon tape. I "think" it was a 1/4 size plug. I got them at home depot, O'reillies and autozone... Nobody had 8 of them so I had to go three different places. Just take the old pipe fitting with you so you get the right size. Hope that helps. ~Arnold
Old Jul 2, 2001 | 02:33 AM
Guest
Guest
Posts: n/a
Its actually straight thread, something stupid like 3/8" UNC I think...
I have brass pipe thread plugs in mine, I think they are 1/4", just like the post above. I wouldnt bother with teflon tape, its just gonna melt away.
Getting the pipe off that goes around the back isnt easy at all, I just left mine on there, it isnt in the way and doesnt weigh much at all.
Old Jul 2, 2001 | 07:41 AM
custman87T/A's Avatar
Behind the heads there is a bolt on each side holding the pipe on and also some ground wires. Use a box end ratchet wrench and take the nuts off and it will come right off. Just remeber to put the ground wires back on. It is also easier if you remove the valve covers.
Old Jul 2, 2001 | 11:41 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I think I had the 3/8 brass plugs too but I cant remember for sure. just put some grey high temp antisieze on em first.
both those rear pipes came out with some strugling for me but it felt like they were just wraped around the harness back there and all I did was move it and the pipes came out.
dont forget to take the pump off too.
Old Jul 2, 2001 | 02:24 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Really quickly do I have to get a smaller belt for my serpentine system? I have underdrive pulleys on there now so I do have a smaller belt but will I need to get an even smaller one since I am getting rid of the AIR?
Old Jul 3, 2001 | 03:07 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Hey Evan, my friend Mike that has that 85 T/A that I used to own is looking into doing that mod as well. He can't stand the look of that crap (who can? lol). His car is a v-belt setup though so he doesn't have to worry bout the belt deal. I saw a tech article (on this site I think) that talked about skipping the AIR pump by routing the belt differently, removing the pump, and getting a slightly shorter belt. I would say that you should be able to look at how much shorter the belt is that they used after they made their AIR pump removal and than take your current belt off and have it measured and get one that is the correct amount shorter. I know that Checker has a belt measuring tool at every store for that type of thing.
Laterzzzzzzz
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, K+N cone, AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, ARAP, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
Old Jul 3, 2001 | 08:34 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Drkhrse89:
Really quickly do I have to get a smaller belt for my serpentine system? I have underdrive pulleys on there now so I do have a smaller belt but will I need to get an even smaller one since I am getting rid of the AIR?</font>
I did. The pic on the tech article is mine (the one with only the smog pump missing). There have been people that rerouted the belt differently IIRC and got the same length to work.
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
