Starting
Old Jul 3, 2001 | 04:23 PM
92Camaro305TBI's Avatar
Starting
When I go to start my car I hear a click, a sec or 2 and then another click. I do it a couple more times and then it starts.. Sometimes depending on how i move the key it will take shorter or longer to turn.... before it starts.... Is that the starter.. It's been doing that for about a year and i think it's getting worse...
Also When I run the car for a little while and "For example" Get gas. Turn off the car go to start it up... It takes a while to Crank. It's 90 weather in fl so.. I know its hot ans nneds to cool off but still... what could I do to prevent this...?
THANKS
92 Camaro 305 TBI Automatic
2.5 high flow cat
2.5 pipes
3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
14X3 O.E. K&N Filter
Future mods.
Headers
any other advise on getting to 300+ HP would be appreciated. Thanks
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Custom box
Rockford 1 farad cap
Rockford 800x2 Amp
4gauge wire kit
Old Jul 3, 2001 | 08:40 PM
Guest
Guest
Posts: n/a
Could be a few things. Either its a weak solenoid, a weak battery, or bad/corroded power/ground connections. Check for corrosion first, if thats not it check out the battery.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
