PinGiNg?????HeLp!!!
Old Jul 3, 2001 | 11:00 PM
idrag2's Avatar
PinGiNg?????HeLp!!!
Hey whats going on? Ok my car is a 89 Formula Lo3 it has a pinging sound coming from the engine Sounds like a lifter tapping but its not I am for sure of that. So what else can cause a Pinging sound? Can a worn out harmonic balancer do it? You can here it best from underneith the car it sounds like its coming through the exhaust? Anyone have any ideas?
Thanks,
I DRAG 2
Old Jul 4, 2001 | 01:18 AM
ws6formula89's Avatar
Sounds like a spark knock to me. One other thing you can check out is the pressure regulator valve in the tranny, if it's an auto. Does it sound like it's grinding/buzzing when in the Drive/Reverse gears? I think that took care of the noise in my car. I also did some head work too, so I might have gotten rid of any "spark-knock" that could have been present. I don't know, people complain about those noises with the L03/700R4 a lot, and the only thing I can say about it is, either forget about the sound, or get it fixed.
The new pressure regulator valve part # is:
(PN: 8684048) Get that checked out.
This noise won't hurt performance at all.
But, I'm just going to build me a 350 and get into the 12s!
-ws6formula-
1989 Pontiac Formula WS6
69,000 miles.
305 TBI, 4.10 gears, SLP Zexel/Torsen Limited Slip Differential, 700r4 Corvette Servo, LT4 Hot Cam/Valvesprings, GM Aluminum Driveshaft, 2700 RPM Stall, Edelbrock Performer RPM intake manifold, Turbocity TB. Ran on 6-19-2001 again: UPDATED: 14.1 @ 97.68 mph. Dyno'd Bone Stock @ 172.6 rwhp, 266 ft-lbs. of rw-torque.
Old Jul 4, 2001 | 02:19 AM
idrag2's Avatar
Well the tranny is a TCI just rebuilt again.
And can I have spark Knock at an IDLE????? How can I fix it if the answer is yes I moved my timing all over and its still there?
Thanks,
I DRAG 2
Old Jul 5, 2001 | 12:18 AM
Well I don't know about at idle...could be stuff rattling [i.e., maybe the exhaust]. Well, just live with the noise, LOTS of people complain about L03 woes. Or get a 350 like I'm planning.
-ws6formula-
69,000 miles.
Old Jul 5, 2001 | 04:28 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
does it get faster with idle? if it does, then it is your exhaust mani
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out....
www.formula350.com
or click below to email me
webmaster@formula350.com
Old Jul 5, 2001 | 05:16 AM
No, I think he described something else other than an exhaust leak. He's talking about a chattering noise at idle. Not in sequence like an exhaust leak should be like. Umm...the best way I can explain it is like he's rattling change in small box at different rates. I had that same problem too, seemed to go away when I got that pressure reg. valve, and head work. Well, you can try that, maybe the exhaust leak is just surfacing and hasn't risen to it's full glory yet...hmm, puzzling!
69,000 miles.
[This message has been edited by ws6formula89 (edited July 05, 2001).]
Azrael91966669
25
Jun 20, 2017 04:04 AM
palric
Sep 17, 2001 12:48 PM
Colin 86&87 IROC-Z
Oct 10, 2000 05:12 AM
