'85 Camaro with running problem.
Old Jul 5, 2001 | 07:23 AM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
I have an '85 Camaro with the carbureted LG4. Today on the way home from work when the car was cold she spit and sputtered whenever I tried to move. She revved up through the RPM's as long as the car was not in gear. As soon as she warmed up she ran strong, about 4 miles of driving.
Any help will be appreciated.
Aaron
1985 Camaro Sport Coupe
LG4, 3.08 rear, A4
Bone Stock
1999 Blazer
4x2, 4.3L, 3.42 rears
Decidedly slow
Old Jul 5, 2001 | 07:48 AM
Red85TA's Avatar
Thats a carburated car, they will all do a bit of spitting and sputtering until they reach normal operating temp the only way to cure it is to get a Fuel Injected car.
Old Jul 5, 2001 | 12:13 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
You may be running a little rich. Since it's when you first started you could probably separate the fact that your trouble is either "cold engine" related or "open loop" related, since it runs OK when warm.
Potential causes:
Plugs, wires, cap, coil, rotor or Distributor Pickup Coil bad.
Vacuum lines off or leaking, especially at the carb.
Intake manifold vacuum leak (bolts not tight).
Carb and/or fuel filter dirty.
Bad CTS sensor.
Pull your trouble codes and see if anything is obviously wrong.
Old Jul 5, 2001 | 03:19 PM
POS Camaro's Avatar
I'll try to pull trouble codes. She isn't throwing the check engine light. Most of the stuff 'looks' like it should effect the car hot or cold. I'll try some of it and see what happens.
92camaroJoe
Jul 29, 2023 07:57 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
Sherpajames
Aug 7, 2015 06:56 PM
