Need some help on TPI
Old Feb 24, 2005 | 02:25 AM
kylez28's Avatar
Car: 1991 z28 camaro
Engine: 350 TPI bored .060 over
Well my car seems to run fine 0-60 when i have it floored, but then at about 65 it kicks down and drops to like 2000 rpm and wont get any higher??
Old Feb 24, 2005 | 02:47 PM
Damon's Avatar
Like the tranny is up-shifting way too soon or like the motor stops making power?
Old Feb 24, 2005 | 03:49 PM
kylez28's Avatar
engine loses power
Old Feb 24, 2005 | 09:44 PM
Vader's Avatar
If you manually shift from OD to D, does the engine regain power?
If you temporarily disconnect the TCC connector, does the situation improve? You can try the same thing with the EGR solenoid, although you'll likely set an error code or two when you do it. You can clear those later, but it may help isolate the EGR.
Old Feb 25, 2005 | 01:08 AM
kylez28's Avatar
I dont know if it regains power after I do that, but it also was running perfect tonight, then it died...my battery/alternator **** is kind of messed up also.
Old Feb 25, 2005 | 01:20 AM
kylez28's Avatar
I mean it just all of the sudden died while i was in the process of whipping donuts(yeah that probably doesn't help) but my car doesn't seem to have any problems so i figured why not video tape some donuts then the **** died, and started right back up no problem then drove away with no trouble, ran perfect
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
