Crazy Coolant Leak
Old Feb 26, 2005 | 03:44 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Crazy Coolant Leak
I have a perplexing problem, I have coolant dripping off the rear main seal housing. I recently had the engine jacked up to remove my headers & while the engine was sitting the leak started. It never did it while the engine was running. I have not started the engine since I discovered the leak. The first thing that came to mind was I cut a heater hose near the firewall when I jacked the engine up. Checked that & found dry hoses. Any ideas would be would welcomed.
Old Feb 26, 2005 | 03:50 PM
brutalform's Avatar
Possibly a rear freeze plug, behind the flywheel. Maybe its leaking from the rear coolant passage where the intake mates with the head, and its running down.
Old Feb 26, 2005 | 03:57 PM
Ricktpi's Avatar
I was thinking freeze plug too, but I don't want to pull the tranny until I am reasonably sure. The rear of the intake is dry,as far as I can tell. This a fairly new motor with about 2500 miles on it.
Old Feb 26, 2005 | 05:25 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
do you have an oil cooler? the factory one uses coolant
Old Feb 26, 2005 | 05:31 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I would try to pressure test the system and crawl underneath the car to locate leak. Rear freeze plugs leaking suck...ask me how I know (on a brand new engine)!!
Old Feb 26, 2005 | 07:39 PM
Ricktpi's Avatar
No oil cooler, that would be too simple. I will try the pressure test method, tommorrow. Good idea, thanks.
Old Feb 27, 2005 | 05:05 PM
Ricktpi's Avatar
Found the problem. Being the front of the car was jacked up, it was leaking from the water pump to block seal and running down and along the oil pan rail, then dripping off the rear main housing.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Jul 23, 2018 08:47 AM
timonator
Sep 30, 2015 12:52 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
