LT1 injectors?
Car: 91 camaro
Engine: 383
LT1 injectors?
Will they work with a TPI setup? I mean will they plug into the harness and also fit in the intake manifold?
91 Z28
Come see The Vicious...
91 Z28
I'm pretty sure they would fit into the intake injector seats just fine, but I don't think that the ECM in your car is ment to work with those injectors, I am sure there are some minor differeces in them, I don't know what they are, but it would surprize me if there weren't some differences in them.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
LT1 injectors work just fine. However, they are rated at a higher flow. 24lbs vs 19lbs (305) or 22lbs(350).
New2Chevy
Sep 28, 2015 12:35 AM
