389 rope seal, does it have a pin?
Old Feb 26, 2005 | 10:39 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Just a quick pontiac 389 question. Does a 389 have a pin in the block to retain the RMS? Lets say a 1959 389. None of my books say and I know there alot of pontiac buffs floating around here.
Old Feb 27, 2005 | 02:06 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Before this gets thread gets locked:
No. The rear main seal on a Pontiac 389 is not pinned or retained in any way.
Trying to replace the seal without removing the crankshaft, eh?
Old Feb 27, 2005 | 07:46 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Pontiacs use rope seals. They need to be "packed" into the groove with a tool outlined in the service manual. If you just lay the rope seal into the groove and assemble the engine it will leak.
There is a new rubber seal(like a Chebbie) that replaces the rope seal available from BOP Engineering.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
