Vortec Cast Iron heads on a 87 305??
Old Jul 7, 2001 | 02:22 PM
Ant87IROC's Avatar
Car: 87 IROC Z28
Transmission: TH700R4
I am seriously considering getting the Vortec heads that are 219.99 in jegs for my motor, will they work?? Do i need to have them machined for valve clearance? Also, will my manifold bolt up? Thanks for any help!
Ant
87 IROC 305 TPI
RAM AIR/Cold air PVC induction
De-screened MAF
Ported and Polished plenum & Runners
TB Coolant Bypass
AFPR
Accel super Coil
Accel Wires, Cap, Rotor
Bosch +4 Platinum plugs
Crane 2032 Hyd Roller Cam 270/276 452/465
3:73 Richmond Gears
SLP Cat Back w/gutted cat
Performance Resource Chip
[This message has been edited by Ant87IROC (edited July 07, 2001).]
Old Jul 7, 2001 | 06:29 PM
rezinn's Avatar
TTT, I don't think this will work with your manifold.
Old Jul 7, 2001 | 07:06 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Nope! If they did I would have used my ported Vortec heads already. The bolt pattern and angle is different. EGR routing is completely different. You can modify them to fit a stock intake. Although this requires drilling and tapping new holes the the head for your intake and disabling EGR in the prom. Keep an eye under the VORTEC thread under TPI, I'm looking into that myself...
I've heard those heads are supposed to make huge torque on a TPI, but haven't found out for myself. SD is supposed to release a Vortec TPI manifold, but we've been waiting for a year listening to excuses. I do know they are now being tested, so they do exist. I'm about to sell my Vortec's and go buy some 'Vette heads. Not a bad 'bang for the buck' head, though. Pretty good for a GM truck head.
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
