Trouble Code help!
Old Jul 6, 2001 | 05:29 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Trouble Code help!
HELP got the new computer in and the car is running good, however I am getting about 15* advance at idle with the jumper plug connected.
I used the auto Xray and got a code 42 ELECTRIC SPARK TIMING MONITOR ERROR
Can anybody help me with this, I do have a new wells module in the top of the dist.
THanks
Brian
Old Jul 6, 2001 | 07:36 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did you set the timing with EST disconnected, then reconnect and plug in the scanner?
If so, you're normal The 42 will stay for 50? starts, or until you reset the ECM
Also, the 15-16* at idle with the EST bypass connected, is normal as well.
Old Jul 6, 2001 | 08:29 PM
Well this is what I did....Turn off car and disconnect the EST then set the base timing at 6* BTDC turn the car off then plug in the EST and start the car.....Put the timing light on and its way past 15* BTDC at idle.......the car is also very low on power.
Thanks for all the help
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jul 6, 2001 | 08:45 PM
Enkil's Avatar
My car was set to 6* BTDC with the EST disconnected... And with it connected, it's somewhere between 20-30* BTDC, so, that's fine..
Starting the car with the wire will set an error code, so that's fine too.. Disconnect the battery for a little while to clear out the ECM, and if the code comes back, THEN you have something to worry about.
As for the lack of power, I'm not sure. With 6* BTDC, you should be running premium gas. Lower gas MIGHT be producing detonation, which would explain the loss of power.
I am assuming you have a TBI, because the TPI's had 6* BTDC as the stock timing.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jul 7, 2001 | 03:28 AM
Well that is the problem we unhooked the battery for about 5 minutes and the started the car and still got the SES light and then I used my scanner and found the code.
Brian
1989 Camaro RS
Old Jul 7, 2001 | 08:36 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hey Brian, the troubleshooting chart for code 42 is to verfiy the wiring on the EST circuit, faulty ignition module, faulty ECM or the memcal is not correctly seated in the socket.
Old Jul 8, 2001 | 07:20 PM
btt
1989 Camaro RS
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
