Will I have to change my flywheel? help!
Old Mar 2, 2005 | 08:45 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I currently have this:
http://store.summitracing.com/defaul...=egnsearch.asp
... with my 1988 305 TPI. I'm putting in a 1969 350. Can I still use this one? If not, does anyone have a link on Summit to which one I do need (same brand and everything)?
Will the Centerforce Stage II clutch/disk I bought work with the new flywheel?
Thanks!
Old Mar 2, 2005 | 08:54 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Sorry, but no. The '69 blocks all had a 2 piece rear main seal, which has a different bolt pattern. Check the bolt holes on the back of your crankshaft where the fly wheel mounts. If it three inches center to center, then this one will work. I'm bettng the hole spacing is closer to 3.5" or so, in which case you need a different one for the earlier model blocks.
Sorry, I don't have a link for you, but I know Summit used to have a McLeod flywheel for the 2 piece rear main seal early blocks. Just make sure its the smaller diameter (153 tooth) model or it won't fit in your bell housing....
Old Mar 13, 2005 | 12:57 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Anyone know what Centerforce flywheel I should get for this? I've been very happy with the one I have, so I'd like to get a simillar one!
Old Mar 13, 2005 | 01:16 PM
sellmanb's Avatar
Car: '86 Berlinetta
CTF-700107
that one looks like it is the proper one. It's 2 piece RMS, and 153 teeth count.
Anyone can chime in to tell me it's the wrong one though... I'd hate to be giving bad advice...
Old Mar 13, 2005 | 01:28 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
In the description of that one it says:
Designed to fit with 6-speed transmission out of a 1993-97 Camaro or Firebird.
So maybe it's not the right one? I hope not, it's $100 more than the one I have!!
Old Mar 13, 2005 | 01:46 PM
sellmanb's Avatar
Car: '86 Berlinetta
CTF-700102
how about that one?
or
CTF-700100
Chuck84TA
Jul 15, 2016 09:05 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 31, 2015 10:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
