catch can location
Old Mar 2, 2005 | 11:48 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
catch can location
I am wanting to buy a pretty shiney catch can to replace my old overflow tank, but I do not know where it could go. I did a search, but the results where sub-optimal. So, where is everybody putting theres?
Old Mar 6, 2005 | 12:22 PM
Vader's Avatar
Are you asking about a coolant overflow tank, or oil vapor / PCV catch can?
Old Mar 6, 2005 | 04:55 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Coolant overflow tank.
Old Mar 7, 2005 | 03:29 AM
Night rider327's Avatar
Car: 1988 Camaro
I mounted my $7 parts store plastic one on the driver's fender, close to the horn.
Did'nt even have to drill a hole to mount it. Just took out the stock fender bolt, slid the mounting bracket in between the two walls, and put the bolt back in
Ran a good rubber hose (not the thin windsheild washer stuff) from nipple on rad, to in front of rad, zip tied it to the core support, then through a hole in the side of the core support, behind headlight, and over to jug. You only see about 4-6" of the hose. The part that goes from the rad to the core support
Attached Thumbnails catch can location-c-documents-settings-john
Pac J
May 17, 2020 10:44 AM
6998poncho
Sep 25, 2015 02:56 PM
Nikole
Sep 24, 2015 08:12 PM
sleprock
Sep 24, 2015 04:33 PM
tonys91rs
Sep 2, 2015 07:07 PM
