Timing chain replacement questions
Old Jul 9, 2001 | 04:35 PM
Hulk0202's Avatar
Is this a pretty straight forward job? I figure you remove the two pulleys and put the new one on, right? I think I may be missing something. did I hear something about removing the distributor?
Old Jul 9, 2001 | 04:40 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Ah.. if you mean the pullys for the belts.. that's just the start of it.
You then get to pull the harmonic balancer, drop the front of the oil pan and pull the timing cover. No the distributor does not have to come out.. but that's about all.
[This message has been edited by jcb999 (edited July 09, 2001).]
Old Jul 9, 2001 | 09:06 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
You don't have to drop the pan, you just pull the timing cover from the top, it will roll out of the pan.
Grind the corners of the timing cover where it has the front oil pan seal lip until it will slide into the block. Do this before you have it ready to install, kind of a test fit.
The cover will roll right back into place.
I never use the new front oil pan gasket they supply, I always use a fat bead of silicon.
Make sure all surfaces are clean and dry and you won't have a problem.
As far as the timing set is concerned, just line up the 2 dots on the old set before you remove it, and install the new set the same.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 09, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
MY87LT
Aug 17, 2015 08:43 AM
redmaroz
Aug 16, 2015 11:40 PM
