which TPS wire do i tap into for nitrous?
Old Mar 4, 2005 | 03:41 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
theirs the black white and blue wire from the TPS, which one do i need to "T" into to make the zex nitrous box function at WOT. i tested with a volt meter and got the changing voltage on the black wire, but when its hooked up, the nitrous doesnt work at WOT. so it must be a blue or white wire, i figured black was gruond anyways,
Old Mar 4, 2005 | 09:48 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Use the Dark Blue
Black is the ground
Old Mar 4, 2005 | 11:02 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Your will get voltage on the black b/c yiour have to ground the 5v to creat a complete circuit.
Blue to black. WOT=4.5v+
Black to blue. WOT=4.5-
And i think the white is the varying voltage signal back to the ecm.
Old Mar 4, 2005 | 11:15 PM
JMatlock88's Avatar
Car: 1991 Formula
The ECM supplies a 5 volt reference voltage at the grey wire.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
mdtoren
Aug 16, 2015 05:45 PM
