Ticking after manifold swap
Old Jul 10, 2001 | 05:54 PM
Boham92RS's Avatar
I recently swapped manifolds for an Edelbrock Performer TBI. After the swap, the engine seems to be running fine. I had to adjust the TV cable, but other than that no performance problems. The engine has developed a ticking when running though. It sounds like it is coming from the passenger side, though it is hard to locate. It echos through the headers, and you can hear it in the y-pipe. The ticking gets faster with RPM's as well. Lifter? Any ideas for a solution?
Old Jul 10, 2001 | 06:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like an exhaust valve that isn't sealing for whatever reason.... possibilities incluse adjusted too tight, burned, bent, seat worn down so far that the valve doesn't close all the way.
ICON Motorsports
AussiePr0nCar
Mar 6, 2020 04:04 PM
db057
Sep 4, 2015 07:57 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:55 PM
