i need a little help!
Old Jul 10, 2001 | 02:43 AM
redlinemike's Avatar
Ok I was having problems starting my car (just a clicking noise when I turned the key) so I stopped trying to start it. I tried again later and nothing happened. The check engine light doesnt even come on. I checked the starter and it was bad I replaced it, and I checked the fusible link coming off the starter and it was good, What should I check next? I have a carb'd 1984 Z28 camaro.
Old Jul 10, 2001 | 10:40 AM
ATOMonkey's Avatar
I'm just throwing some things out here. You replaced the starter and it still just clicks? Is the battery charged? Did you check the wire that activates the solinoid? Not much else to go wrong.
'87 Bird 350 .060 over 700R4 + Lots more
Old Jul 10, 2001 | 11:59 PM
i check all the wiring and battery and it was all good. i replaced the starter and still nothing happened, went to bed came back in the morning did not touch anything turned the key and she started right up. Maybe the car repair fairy showed up last night. it worked fine all today still cant figue out what happened
