K & N X-Treme Top Plate
Does anyone run this with an open element air filter? Right now, I have the K&N open element filter, with the shiny chrome K&N top to it. Would I notice any gains by adding this filter as my top piece (I assume I could do this?)? Or would it really be pointless unless I'm running a tonne of power and need the extra air?
Trevor
87 Z28 - Carb'ed 305
Hedman Headers, Y-Pipe, Dynomax Exhaust, K&N Open Air Filter
Trevor
Im sure you dont need any more air flow unless you've got something that demands all that air, liek a blower.
1992 Pontiac Firebird
- 305ci V8 TBI / Automatic Trans / Loaded
- MODS: Edelbrock 14x3 Open Element Air Cleaner, Dual outlet exhaust
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use one. The more clean are I can get into the engine the better. It helps to have an open area above the filter. If the top of the filter is just below the hood then it's not worth it.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
i use one with an open element- but on the other hand i have a cold air box and a cowl hood
Steve
Steve
So on a stock hood, there really wouldn't be much air getting in there then, right? Making it pointless to spend $50 on it?
Trevor
87 Z28 - LG4 - 305
Trevor
87 Z28 - LG4 - 305
1992 Trans Am
May 10, 2023 07:19 PM
gixxer92
Sep 1, 2015 04:32 PM
