Going from HOT cam to Comp XE282HR, what to expect?
Old Mar 6, 2005 | 06:41 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I just ordered up a comp XE 282 HR cam and will be installing it on thursday. It will be replacing my HOT cam. I am tired of pulling hard, then smacking a wall at 6000 rpm. I want it to scream to 6500. I think my cam and valve springs are holding me back with my setup.
Engine is a 350 flat-top pistons, zero deck, .028 head gaskets, 10.6 compression.
Edelbrock E-Tec 170 Heads
Edelbrock 7116 RPM intake
Holley 750 DP HP carb
Here is my valvetrain setup:
LT4 HOT cam I 218/ E 228@ .050 I.525 E.525 lift
Comp pushrods
Comp Pro Magnum Rockers (1.6)
Edelbrock Valve springs/Retainers
I will be changing out those parts to these parts:
Comp XE282 HR cam 230/236 I .544 E .555 lift (1.6)
Comp 987 valve springs
Comp 730 Titanium Retainers
Comp 10 degree locks
What can I expect from this cam in a 350 engine?
Is anyone running this cam in a 350?
gixxer92
Sep 1, 2015 04:32 PM
mz92274
Aug 25, 2015 08:47 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
