Locked out!
Old Mar 8, 2005 | 06:06 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
Locked out!
omg this is a realy dumb question to ask you guys but how do you get in your car if you left your keys in there?
all doors are locked and i cant get in any tips would be helpfull
Old Mar 8, 2005 | 08:16 PM
Vader's Avatar
Use the spare key.
Call a locksmith.
Use a lock bar (if you have one) .
Use your picks and shims to set and open the lock (if you have them).
Try to reach the release switch or slide **** with a stiff piece of wire (without damaging the window seals) and slide or depress it to release the door.
Old Mar 8, 2005 | 08:26 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
cry
Old Mar 8, 2005 | 10:03 PM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
Transmission: it works I'm happy
call triple A or some tow company chain. (time to sign up for one first though)
They have guys who will break into your car for you with no damage .all part of the service.
Ask me how I know this
Old Mar 8, 2005 | 10:16 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
ok i got this one
i've done it before.. ok get 2 or 3 stong guys you can get a hold of the window glass form the top and the push it down find some one with really skinny arms and reach in thier and unlock the t-tops then whalla your in.. don't ask me how i know this....
Old Mar 8, 2005 | 10:27 PM
Lason's Avatar
Originally posted by ridecamro
ok i got this one
Yup, I can break into any 3rd gen this way in under 20 seconds. I have had to do it more than once and its pretty easy to do by yourself. Only difference is I grab the glass at the top and pull it out. Since there is no upper channel for the glass to sit in it will bow out a good 6", or just enough to reach in and unlock it.
Old Mar 8, 2005 | 11:06 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Um. You're overlooking one thing. You said "unlock the t-tops". Ok, so, with that key you ust to unlock it, you save the effort and unlock the door!
Old Mar 9, 2005 | 10:36 AM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
I think discussing methods of how to break into a thridgen will get this thread locked.
I'm going to PM you dude with another illegal entry tip.
Old Mar 9, 2005 | 12:06 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Doesnt really matter, search Google:
http://www.google.com/search?q=break+into+camaro
2nd listing....
Old Mar 9, 2005 | 12:33 PM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
Thats a very comforting set of links you just posted
the guy in the second link is just a little bitter.
Thirdgen.org isn't google though is it?
but enuff said I get your point.
Old Mar 9, 2005 | 12:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The ruler trick... Its got my door open a few times.
Car: 85 Trans Am
But also remember the more we know about how to steal them, the more we can try to protect them
The article is from a pathetic stand point but still a good bit of information to attempt to prevent.
Old Mar 9, 2005 | 01:00 PM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
Yeah all info is good it's the "pregnant tropical fishes" that use it thats the problem.
I've 3 different locks on my car,plus the ignition, only 2 keys. The door I have the key for got frozen shut and now is waiting for spring till be fixed. until then any passengers have to crawl over the center console. My key coded ignition crapped out on me the other day and had me stranded for an hour fiddling with it...
I've taken to throwing a tarp over the car at night so the doors don't freeze shut. The car runs without the key but only starts with it in!!!!!
I have trouble getting in and going so good luck to some **** hair plucking ****** who would want to steal it..
Old Mar 9, 2005 | 06:24 PM
3rd gen V8's Avatar
Oh i forgot that i have electric door locks i gess ill try to get a hanger and try to poke at the passenger side door and hope that works. and oh i tried to pull on the window and no luck
Old Jan 16, 2008 | 12:34 PM
thinkdifferent's Avatar
Re: Locked out!
I just got locked out of mine! RAC patrolman sorted me out... I was installing remote locking at the time - d'oh!!!
Old Jan 23, 2008 | 12:07 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Locked out!
I use my lighter pull the window from the modling out to me, grab with fingers, with slow steady, hard pressure pull window to yourself, then u can get your arm in there to get the t-top lever or use a coat hanger to poke ur trunk release switch if you dont have tops or they are locked
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
