10134358 GM parts Camshaft have lobe for mechanical fuel pump?
Old Mar 9, 2005 | 01:12 AM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
I have a set of ZZ4 heads with the ZZ4 springs/pushrods and comp cams 1.52 roller tip rockers. Im going to put a carb on it. Does this cam (10134358) have a lobe to run the mechanical fuel pump i want to use?
Old Mar 9, 2005 | 06:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
10134358 Valve Spring
This is a special performance valve spring used in ZZZ-ZZ1-ZZ2-ZZ3 350 create engines. This is a good spring for mild to high performance engines.
Technical Notes: Single spring with damper with 1.273" O.D. and 1.16" solid height. The pressure at installed height is 110" @ 1.70" with 356" the average rate of pounds per inch. Made of Chrome Silicon Steel with color code of orange. Use with retainer P/N 14003974 and seal kit P/N 10132715.
I could be wrong; but I don't think those have fuel pump lobes.
Old Mar 9, 2005 | 12:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Weren't those crate engines meant to use carbs though?
Old Mar 9, 2005 | 01:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some of the engines were designed for carb use, and consequently need a fuel pump lobe on their cam; and some of the cams even in motors designed for FI have fuel pump lobes, just because they're ground on blanks that already have them; but the part # he posted is a valve spring. I seriously doubt there'll be a fuel pump lobe anywhere on a valve spring, regardless of whether the spring was intended for use with a carb or not.
Hopefully he'll realize his mistake, and post his cam part # instead of his spring part #.
Old Mar 10, 2005 | 12:12 AM
haha, ya sorry. I copied the wrong #. It's the ZZ4 camshaft Im talking about. those springs are for the ZZ4 too but I didnt mean those.
Old Mar 10, 2005 | 05:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sorry, but it was pretty hard to tell what cam you were wanting to know about....
Yes, it does. In fact I just put one in a motor the other day, with a mech pump.
Let me give you a hint:
Go to ebay, cars& parts, type in "ZZ4"; you'll get to see about a dozen pictures of it. Best place there is, for finding pictures of things.
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
