Does anyone know if Comp 987 springs will swap onto Edelbrock Heads?
Old Mar 8, 2005 | 10:07 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I need to change the Edelbrock valve springs to Comp 987's and I know that the 987 are smaller on the out side ( 1.43), but will the inner spring fit over the valve guide seal ok?
Has any one done this swap ?
Old Mar 9, 2005 | 06:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
They fit fine. The guides on the Edelbrock heads are .530" OD IIRC, and the ID of the 987s is something like .690" IIRC. There's even room for a good quality seal like the Comp 500, or the equivalent from Crane or Manley or whoever.
They are arbitrarily close to the same outer diameter as what came on the heads.
Old Mar 10, 2005 | 10:25 AM
GASGZLR's Avatar
Thank you MUCH RB! I am in the middle of the swap right now.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
