How to change vavle springs?
Old Mar 9, 2005 | 02:37 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
i just won a set of 416 heads off of ebay for $30.00. I am going to try to put new vavle springs and maybe new valves in but ive never done it before, is this hard to do? Can some one tell me how? Also what kind of springs should i use?
Old Mar 9, 2005 | 03:11 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You need a valve spring compressor. Use whatever springs your cam manufactutor recommends.
Old Mar 9, 2005 | 03:19 PM
ede's Avatar
ede
and replace the seals while you're doing it. look in your manual and you ought to find a pic or two. after you're done give the valve tip a good smack with a brass or soft hammer to make sure everything is seated.
Old Mar 9, 2005 | 09:30 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Is this hard to do?
Old Mar 9, 2005 | 09:44 PM
91Z28-350's Avatar
I'd also recommend getting a valve spring height micrometer to measure the installed height and add the necessary shims as needed.
Old Mar 10, 2005 | 11:52 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Originally posted by del91_305
Is this hard to do?
No, it is actually pretty easy if you have a good spring compressor. This is the one I have...it is a little time consuming having to thread it onto each stud, but overall works well.
Also the spring height micrometer is a good idea. I had to add something like .105" (.060 + .030 + .015) to mine to get the proper install height with my COMP springs on my 416's. I got the shims from Competition Products.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
gixxer92
Sep 1, 2015 04:32 PM
johanlindgren
Aug 16, 2015 12:16 AM
