home made gaskets??? for tpi
Old Mar 11, 2005 | 06:10 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
hi i just got a pair of vary parted slp runners i got them from mike graycar and he was sayin he made his own gaskets, does anyone know how to do this? im having a hard time cutting gaskets to work with the ported parts!
Old Mar 11, 2005 | 09:21 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes, you buy a roll of rubber gastket. most part stores have this. it is like cutting very thick papper (or very thin cardboard) yes it is some what of a pain to do but, works.
I traced the runners on the material then I cut out the main shape.
then I made x marks where the bolts needed to go.
then install bolts to hold the gasket in place.
then I took a knife (razer, knife- what ever feels good while you cut) and cut the inside part out (almost like tracing the inside of the runners using the tip of your cutting tool . just take your time and you can always go back and trim the inside closer
Old Mar 11, 2005 | 09:39 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Isn't there a gasket making punch set for such a purpose? Haven't used one but could swear I saw one somewhere. It has difirent radius sizes for different cuts ect.
Sometimes I make my own gaskets for minor things out of RTV. I'm yet to put a bought gasket on a diff cover or thermo housing.
TheExaminer
Aug 26, 2015 04:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
