push rods...
Old Mar 11, 2005 | 07:10 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
push rods...
Old Mar 14, 2005 | 12:46 AM
Vader's Avatar
Stock push rods should have been 7.200". You can not run the engine with the length checler. You should assemble on pair of valves with checking springs (very light pressure) and bolt a head on the engine with a couple of bolts torqued very lightly to mock up the assembly. With the timing chain correctly installed and lash adjusted as well as you can with the checking springs, rotate the engine until you are certain you have impressed the clay. Remove the head and check the remaining thickness of the clay on the piston. That is the clearance (or interference) amount.
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
92projectcamaro
Sep 29, 2015 07:07 PM
