yet another rear ???
Old Jul 14, 2001 | 01:19 PM
thefastest's Avatar
I recently bought this rear from a junk yard. when I opened the diff. cover I noticed that the gears were filled with a wettish rust.(looks like they lost the plug and left it outside) rain most likely got inside the hole how do I fix this problem?
Old Jul 14, 2001 | 01:38 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
agh..
bad sign... you may be able to use them if there's only surface rust, pitting is very bad..
Webmaster: www.IROC-Z.org
Old Jul 14, 2001 | 02:29 PM
thefastest's Avatar
it is only surface rust. I can wipe it off with my finger
Old Jul 14, 2001 | 02:38 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Get some diff fluid (80-90) and flush all the gears and stuff off. If it just wipes off, they should be OK.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 14, 2001 | 03:04 PM
Bort62's Avatar
The Carrier I am currentyly using was sitting outside in the rain for several Months.
When I got it, It was all full of leaves and rust and junk, I soaked it In used Motor Oil and cleaned it up, and it seems to be working fine
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
