Switching distributors??????
Old Jul 13, 2001 | 06:28 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I have a question i have 87 iroc with an lg4(peanut roller cam)And i want to take the original distributor out and put in a non computer controlled distributor in, everything else from the car is not using the computer(carb,tranny,and so on)the question is with switching distributors do i have to switch the gear on the bottom of the old distributor to the new one.Any help would be great.........
1987 BLUE IROC
IT'S A DOG
BUT IT'S MY DOG
AND IT HAS A NASTY BITE......
CNYFBA MEMBER
http://cnyfba.cz28.com/
Old Jul 13, 2001 | 09:26 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
gears are the same..
if you are going vacuum advance i believe you just leave the computer stuff disconnected and run the engine like a 70s engine.. you already have a mechanical fuel pump, just get the standard HEI distributor with vacuum advance..
Webmaster: www.IROC-Z.org
Old Jul 14, 2001 | 12:21 AM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Yeah that what im goona do.But i was told that the distributor gear was different on a roller cam...
1987 BLUE IROC
IT'S A DOG
BUT IT'S MY DOG
CNYFBA MEMBER
Old Jul 14, 2001 | 06:46 AM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
Most probably the gear from the computer contolled distributor will not fit on the vac adv dist. The shaft sizes are different.
I believe what you are talking about is the material the gear is made out of. I do remember hearing that the stock dist. gear will get chewed up by the dist. drive gear on the cam. BUT I do NOT remember if what I heard was referring to a stock cam or an aftermarket cam.
Maybe some else here can shed more light on this for you
LOBC-- SS-84
92 RS Heritage package with a 305 3" high-flow cat and pipe with a Dynomax 3" in dual 2 1/2" out.
84 El camino- 383 CID, Performer RPM, GMPP vortec heads, Holley 750 D.P.(0-4779c), Crane Energizer 274,Dual 3" Flowmaster 40 Series Exhaust, Turbo 350 (375b), TCI 2500 stall, Richmond 3.42 gears, PST Poly graphite Suspension bushings, PST steering linkage, PST springs, Monte SS sway bays, Wheels from a Third gen(does that count?)
Old Jul 14, 2001 | 10:56 AM
Engine: 305TPI
are you sure?
why is it that when you buy a new roller camshaft for a car that wasn't factory equipped with roller cams that you don't need to change the distributor gear..
i believe it's standard chevy, dude. i just pulled the distributor in my '86 and it's exactly the same as my '87 minus the top of the distributor differences... gear-wise they are identical
Old Jul 14, 2001 | 11:18 AM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I was told that the gear sizes are different and that a roller cam uses a different size gear.A friend of mine did this in the same camaro(87iroc lg4) and the gear from the vac advance distributor started to grind and wear down the gear so then had to put the old conputer control distributor back in his car.I just dont want screw up the car so i want to be sure............
1987 BLUE IROC
IT'S A DOG
BUT IT'S MY DOG
CNYFBA MEMBER
Old Jul 14, 2001 | 01:20 PM
SS-84's Avatar
Car: 1992 RS
AFAIK
the mesh of the gears is the same.
Later dist. have a smaller shaft (.490)
HEI vac adv has a bigger shaft (.500)
The factory cam has a cast iron drive gear.
SOME aftermarket cams use a billet drive gear. If the cam has a billet drive gear, you have to use a bronze driven gear or the cast iron gear will be chewed up.
Check this page at Jegs.
http://www.jegs.com/cgi-bin/ncommerc...%202393%202394
It was the only thing I could find real quick.
LOBC-- SS-84
Old Jul 14, 2001 | 03:42 PM
Bort62's Avatar
you need a melonized ( bronze) dist gear For use with a Roller ( non hardned) Camshaft.
Or you will Chew it up In a few miles.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
