HELP! Fuel/AN Fittings and Hose Q
Old Jul 13, 2001 | 07:07 AM
Superblue87Formula's Avatar
Okay, I have never worked with fuel fittings and hoses b4, and I'm kinda stuck. I need to connect up the following:
Hose 1:
Fuel Line (3/8 flare male) to Regulator (3/8" NPT female)
Hose 2:
Regulator (3/8" NPT Female) to Carb fuel line (3/8" Inverted Flare Female)
If someone could tell me what fittings and hose size to use (either twist-lok or braided) It'd be most appreciated.
-=1987 Formula 350=-
Member Greater Cincinnati F-Body Association
Old Jul 13, 2001 | 01:41 PM
ede's Avatar
ede
3/8 is -6, i can't quite picture what you're doing but if you take what ever fittings you can to an industrial hydrolic supplier you can get hoses made a lot cheaper than buying the fittings for hot rods from jegs, only draw back is you can't get the pretty anodized ones.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 13, 2001 | 03:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you trying to connect to the stock hard line in the engine compartment? What type of carb do you have, or do you have a dual feed carb line or something already?
Old Jul 14, 2001 | 09:23 PM
yes I'm trying to connect to the stock hardline and I also have a dual feed carb line (came w/ my holley 750)
thx
Old Jul 14, 2001 | 09:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm not sure how your factory line ends now, but I like to cut the end off, slip a tube nut on and flare it. You'd need something like:
<table border=1><tr><td><strong>Qty</strong></td><td><strong>P/N</strong></td><td><strong>Description</strong></td></tr><tr><td>1</td><td>581806</td><td>-6 Tube Nut</td></tr><tr><td>1</td><td>581906</td><td>-6 Tube Sleeve</td></tr><tr><td>2</td><td>820166</td><td>3/8 NPT -6 Hose End</td></tr><tr><td>2</td><td>800106</td><td>-6 Hose End</td></tr></table>
And enough hose to reach everywhere.
The P/N's are Earl's, but you could use Aeroquip fittings and hose too. Aeroquip doesn't make pipe thread hose ends, so you'd need 2 more -6 hose ends and 2 -6 AN to 3/8" NPT adapters.
[This message has been edited by Apeiron (edited July 14, 2001).]
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
89 formula TPI
Sep 7, 2015 10:19 AM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
