Oil cooler removal questions.
Old Mar 12, 2005 | 06:35 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I am removing my stock coolant oil cooler, and will eventually put on an aftermarket oil cooler.
My question is do i need a new oil filter adapter, or do i just need to replace the two bolts with ones that have shorter heads. I already took off the factory oil filter coolant sandwich and I tried to put the filter on, but it was hitting the bolt heads.
My main question is can i use the stock adapter that is already between the sandwich and block.
Old Mar 13, 2005 | 01:16 PM
pellmanm's Avatar
Car: 1989 GTA
Could someone please answer this questions if you know, i need to know ASAP. Thanks.
Old Mar 14, 2005 | 11:24 AM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Shorter bolts should do it. I took mine off for good. I'm running a 7qt. oil pan so I don't need it.
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
