Help needed here... really badly...
Old Jul 14, 2001 | 11:11 PM
Roshambo's Avatar
Ok, Ive got a 1988 T/A 305 TPI, I just replaced the heads with L98 Aluminum heads. I removed all emissions stuff, replaced my, spark plug wires, ignition module, and rotor. Everything is hooked up, the motor has been gone over tons of times. Here is my problem, the motor cranks, but, doesnt start. The head scratcher is this: I get 12 volts into the coil, and NONE out! I just replaced the OEM coil with a MSD Super coil about 1 month ago, I had the OEM coil laying here, so I tried it. Same thing.. no spark out of the coil. I thought it was the ignition module, so I just replaced that. Anyone have any ideas at all? This is driving me insane... please help!
-Roshambo
Old Jul 15, 2001 | 12:11 AM
Roshambo's Avatar
Old Jul 15, 2001 | 01:38 AM
maksik7's Avatar
You prolly did this, but check all the wires going into the ignition system, one of em might have gottne disconnected. Your problem sounds like power not getting to distributor so I would check all the wires connected to the bottom of it.
I had this same exact problem and one little wire under the distr. got loose while I was changing the plug wires and it would turn over but wouldn't start.
Hope it helped...
-Max
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
