89 rs anti-theft hell!!
Old Mar 14, 2005 | 10:53 PM
mikeage2's Avatar
Hi guys! i have a 89 rs i got for parts...no keys... i chenged the ign, but the old igh iad cintacts in it,the new one doesent. I believe this car is supposed to have a pellet in the ign key. SO my plan was just to solder a resistor across the 2 wire going to that.....so the antitheft sees that resistance and thinks everything is fine..... ok but bieng i have no original key i dont know what the resistance was for this car. My 90 iroc has a 7.5 kilo-ohm resistance across the chip on that ign key...i tried that on the rs,but still nothing...no starter engagement,theft light on. so i checked my cadillac...is has a 1.7 kilo ohm resistance. I tried that,still nothing.... does the 89 have yet a another resistance that my 90 iroc of my cadillac??? PLEASE SOMEONE HELP!!!! !i just need to get this car runing to i can see of the motor +tranny are and good. I can manually jumper the starter,but car still wont start,because the computer is also killing the fuel. help me out mang!!!!
Old Mar 14, 2005 | 11:28 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
they have 15 vats key codes.
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
they used all different resistances in those keys, and the ecm has to read the right resistance. its an added antitheft. if all keys were the same resistance, it would be quickly figured out and thier would be almost no point for it, just an extra obstacle for the would be thieves.
Old Mar 14, 2005 | 11:50 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
There are 15 different resistors used. If your close they will work. I don't know what the 15 are tho.
Old Mar 15, 2005 | 12:45 AM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
Wait
Since when do 89's have the vats system?
I know mine didnt
or did someone do something to mine?
Old Mar 15, 2005 | 12:50 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
in 89 it came stock with vats, if yours doesn't its been disabled
Old Mar 15, 2005 | 07:29 AM
mikeage2's Avatar
WELL OK I FANYBODY KNOWS WHAT RESISTANCES THEY ARE ILL TRY EM ALL. THANKS
MIKE
Old Mar 15, 2005 | 08:14 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
http://www.asttraining.com/Files/vats1.pdf#search='VATS%20RESISTANCE'
Old Mar 15, 2005 | 06:57 PM
mikeage2's Avatar
THANKS ALOT!!!!! IVE GOT TIME ILL KEEP TRYING TILL I GET THE RIGHT ONE.... BTW IF SOMEBODY ELSE IS TRYING THE SAME THING: IF YOU DIDNT GET THE RESISTANCE RIGHT,TURN THE KEY BACK OFF.... YOU MUST WAIT 4 MINS THEN YOU CAN TRY A DIFF RESISTOR.
MIKE
Old Mar 15, 2005 | 08:44 PM
mikeage2's Avatar
IS THERE ANY OTHER WAY TO DITCH THIS SYSTEM??? IVE TRIED EVERYTHING CANT GET HER TO FIRE. THEFT LIGHT KEEPS COMING ON... AT THIS POINT I GIVE UP I GUESS ILL SELL THE MOTOR AS IS . ILL START RIPPING IT APART SOON SO AGAIN ANYONE NEEDING 89 RS 305TBI PARTS LEMME KNOW!
Old Mar 15, 2005 | 08:45 PM
mikeage2's Avatar
oH YEAH. WHERE THE HELL IS THE PATS MODULE ANYWAYS? I RIPPED THE PASS DASH APART AND FOUND A MODULE BUT THE WIRES DONT CO-ENCIDE WITH MY DIAGRAM I HAVE FOR THE PATS SYSTEM
Old Mar 15, 2005 | 10:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is the VATS control module and it is located on the firewall behind the defroster vent on the drivers side by the right foot. BTW, the module you found on the passenger side was the cruise control module.
Old Mar 25, 2005 | 08:40 AM
84z28ss's Avatar
does the VATS controller need the resistance, or does the ecm.. i have another parts camaro laying around with the original keys and another ecm.. if i switched the 2 ecm around then switched over the cylinder locks, would the system work then, or does the "passkey" (VATS) need a certain resistance, or is it in the computer??
thanks
dfelton26@hotmail.com
Old Mar 25, 2005 | 10:20 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The resistance value in thte key is read by the VATS controller module which then sends a signal to the ECM if the resistance value is correct. Switching the ECM's and lock cylinders would not help you in this case. You would need a key with the correct resistance value to match the VATS module.
Old Mar 25, 2005 | 10:54 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
look on ebay and get a VATS bypass box if you want to bypass it...
it sends the correct signal to the ECM, making it think the VATS is there...
or keep trying key resistances.
Old Mar 25, 2005 | 01:49 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thye sell little boxes like mentioned above for remote starters. They have dip switch settings for resistance, you could use one of these boxes to hijack the vats system but you still need to find the correct resistance, that PDF will provide all the needed info.
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
