I nned help
Old Jul 15, 2001 | 08:14 PM
thefastest's Avatar
I nned help
Im removing my rear(switch). I do not know how to take out the torque arm from the shorter side. can someone help
P.S.-- im not refering to the side with those two big bolts
Old Jul 15, 2001 | 08:49 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
there's a bracket on the transmission that you will need to undo.
Thre's also a bolt that holdes the bracket together, forcing the rubber to contract around the torque arm.
Loosen that, and the bracket on the tranny and you should be able to wiggle it out.
Webmaster: www.IROC-Z.org
Old Jul 15, 2001 | 10:09 PM
iroc5speed's Avatar
you don't even need to remove that side, just let the torque arm hang. On;y take off one side of everything, then it will be easier to reinstall everything, and everything should line right back up.
Old Jul 15, 2001 | 11:55 PM
Engine: 305TPI
sounds like he wants it off, i dunno..
maybe he's putting an adj. torque arm on? who knows, lol
pimpimusmaximus
Mar 7, 2013 05:29 PM
A88GTANotchback
Jun 9, 2004 01:12 PM
84cj7305
Apr 29, 2004 05:39 AM
