dieseling?
Old Mar 15, 2005 | 12:25 AM
rjmcgee's Avatar
dieseling?
What causes it too diesel when I shut it off? Not everytime, sometimes when it is cold and sometimes when it is hot. Been experimenting with the timing and have the base at 14* right now which is prolly why it started this, but what actually causes this?
Thanks,
Old Mar 15, 2005 | 12:36 AM
DeLorean247's Avatar
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
HI
Mine does this too.. It stopped alot when I put my timing to 6* But it happend again today.. My carb is the last old part on my car since the new engine and I know its running way rich.. Maybe Running rich causes this?
Old Mar 15, 2005 | 12:44 AM
Slag02's Avatar
Car: 85 Suburban
Transmission: TH400
Not sure as to the why but i know a easy fix....
Shut it off in Gear (Reverse or Drive dosent matter)
Works every time for me.
Just a suggestion
Old Mar 15, 2005 | 12:46 AM
Engine: 350 Carb
Ya that does work. And iv put it in Park and shut it down at the same time with my left hand and that works for me too.. Maybe because the RPMs have not come back up yet?
Old Mar 15, 2005 | 01:02 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Dieseling is primarily caused by too much timing or an idle speed that is too high. Also, excessive age in the form of carbon deposits. I have even heard cases of the fan staying on acting much like a generator powering the ignition.
If the timing is off, hot spots in the combustion chamber can occur. These hot spots can get hot enough where they act like a mini spark plug and will actually ignite any unburnt fuel and air that happen to be in the chamber.
Obviously running rich will cause carbon deposits over time. Those carbon deposits have the same effect in ways of absorbing heat then acting as a spark plug.
With a carbureted car, if the throttle blades are open too far, aka - idle speed too high, enough fuel and air will still be fed into the engine to allow it to run on as it is. A throttle stop solenoid can be installed or adjust the idle speed (the more common fixture).
Old Mar 15, 2005 | 02:05 AM
anondude13's Avatar
Yeah I've heard it's hot carbon deposites in the cylinder head igniting fuel. You may want to try running some seafoam or diesel fuel into a vacuum line leading to the intake (I use the PCV line for this job). Slowly pour it in while the car idles making sure it stays running and then really dump in the last portion of it to stall the car out. Let it sit for a few minutes and then start it and give a good spirited drive. This should clean out the carbon deposites and stop the dieseling.
school boy
Oct 22, 2015 11:47 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
MoonDog
Jun 14, 2002 12:37 AM
86Trans Am
May 12, 2001 02:10 AM
