MSD distributor
Old Mar 15, 2005 | 06:08 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
MSD distributor
my S10 currently has a 4.3L V6, that is soon replaced by an L98. i have a MSD distributor (p/n 8367) in it, and was wondering if it can be converted to V8 (p/n 8365)use. i know that on the factory unit, you can change the module, and reluctor, and you're good to go. anyone know if the same holds true for the MSDs?
my timing is erract, and when i last pulled the distributor, there is a fair amount of play between the gear, and the top of the shaft. i assume this is what causes the timing to jump, so maybe its something that MSD can fix. if so, maybe they can replace the V6 stuff with V8s. any ideas?
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
Damon
Sep 26, 2015 04:29 PM
