few questions inside
Old Jul 16, 2001 | 02:08 AM
pimpintheRS's Avatar
okay first i got a new fuel pump about a month ago and it has been surging when i acclerate from a stop it only does this in the lower rpm's. if i punch it it doesnt do it. Another thing is my car is running alot hotter this summer could my car be running lean now with the new fuel pump? any suggestions will be appreciated thanks
Shawn
91 RS 5.0 TBI
14x3 open element.. i liked alot
160*stat... made my car run a lil cooler
msd coil and taylor wires ...not noticed
with ac delco plugs.. i like
removed rear hood seal.. runs much cooler i liked
accel cap and rotor..not a real mod
coming soon 3.42's with slp posi.. my first big mod!!!
Clarion cd player 2 planet audio 6x9's 2 lanzar tweeters and one MTX 10" sub in a bandpass all running off 2 separate 200w amps
Old Jul 16, 2001 | 03:00 AM
rezinn's Avatar
Maybe a stupid question..did you change the fuel filter?
Old Jul 16, 2001 | 03:26 PM
i changed it about 3 or 4 months before i changed the fuel pump. do you guys think the fuel filter could really have that type of an effect on my car?
Shawn
Old Jul 16, 2001 | 03:28 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
running hotter could be the thermostat sticking a bit or incorrect mixture of antifreeze and water..
change both, check your hoses while you're at it
Old Jul 16, 2001 | 03:34 PM
changed the thrmostat twice already i bought a 160 stat i live in phoenixc we need the lower ones. i have only one puller 16" fan and have intalled to pushing fans one is a 12" and the other is a 10" i am going to check my hoses since they have been on the car for a while.
any other suggestions?
Shawn
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
