Can Water-locked Cylinder Cause Block to Crack on Start Up?
Old Jul 16, 2001 | 11:41 AM
TomS's Avatar
My 89 350 TPI with 62k miles blew a head gasket and water filled up #7 cylinder after I parked it. When I tried to start it later the water stopped the engine. I didn't know what was going on so I kept trying and it eventually started. When I saw the white smoke I shut her down immediately. After taking off the heads, I found water in #7 and some odd looking horizontal scratches about 1" from the top of the cylinder that might be hairline cracks.
Can starting with a water locked cylinder cause the block to crack?
Old Jul 16, 2001 | 12:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't think you could devlop enough pressure to crack a block with a hydro-locked cylinder??, I have heard of bending rods though.
Were the lines up and down? Could be scratches?
Old Jul 16, 2001 | 12:15 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i wouldn't think so either..
are you 'positive' that your headgasket blew? possibly you cracked the block and mistook it for a headgasket?
are the horizontal lines perfectly straight or crooked?
Webmaster: www.IROC-Z.org
Old Jul 16, 2001 | 12:28 PM
TomS's Avatar
Two engine rebuilders just told me it is possible to crack the cylinder and bend the crank or rod when a cylinder goes hydraulic. The cracks in my cylinders are irregular, not a straight line. I am going to try some over the counter dye penetrant crack tester.
Old Jul 16, 2001 | 12:58 PM
gravitar's Avatar
It is definitely enough to damage a motor. A guy I know has a Quad-4 Grand Am, and he drove it through a puddle about 6 inches deep. He swears he wasn't going too fast, but it was enough to fill a cylinder with water and send a con rod right through the side of the block!
Old Jul 16, 2001 | 03:55 PM
Guest
Guest
Posts: n/a
Yea it can crack the block although thats the least likely part to get damaged. Usually the crack is either from a flaw in the block or cold water getting into a hot engine.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
