torque spec for screw in rocker studs
Old Mar 17, 2005 | 02:18 AM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
i'm building a 357 with dart II heads, i'm getting ready to install the new 7/16 screw in rocker studs. i've searched for this and found multiple different answers, what i need to know is the torque, in my search i've found suggestions from 10 - 65 ft. lbs. i need a more specific spec. also, what about thread sealer/locker? i've found some that suggest loctite, and some that suggest thread sealer, which should i use?
Old Mar 17, 2005 | 06:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They should be around 50-55 ft-lbs.
Or, if you don't believe me, you could check with World.
http://www.worldcastings.com/tech/sp...inderheads.doc
Use thread sealer, especially on the intake; they go right into the intake ports, and if the threads aren't selaed, they'l suck oil right straight into the port, like bad valve guide seals except worse.
Old Mar 17, 2005 | 11:12 AM
Engine: 357
ok, thanks a lot, thats what i'll do then
Old Mar 17, 2005 | 11:15 AM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
yep 50-55 sounds right.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
