braided hose tips..
Old Jul 16, 2001 | 10:28 PM
Superblue87Formula's Avatar
braided hose tips..
well I keep fraying this fuel line and cutting the **** out of myself, can anyone give me some pointers??
-=1987 Formula 350=-
Member Greater Cincinnati F-Body Association
Old Jul 17, 2001 | 12:33 AM
iroc5speed's Avatar
try wearing mechanix gloves(I think that's spelled right), and maybe a long sleeve shirt.
Old Jul 17, 2001 | 01:37 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Are you trying to install AN fittings on the hose? Try this tip I learned from a friend who is a hydraulics specialst on aircraft...
Wrap a little electrical tape around the hose end where you want to cut. This makes sure you cut the hose straight and the ends won't fray out while you cut it. Be sure to put the hose in a vise when you cut and use a hacksaw to do it. HTHs.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Jul 17, 2001 | 02:13 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Wrap the tape tight around the hose before you cut. I like using a high speed cut-off wheel rather than a hacksaw, if you use a hacksaw make sure you use the sharpest, finest blade you can find. Use a pair of good side cutters to trim any loose strands.
If you're having trouble getting fittings on the end because the braid is flared out a little, stick a worm-type hose clamp on the hose with about 1/8" sticking out and tighten it down to squeeze the hose until you can get the end started.
Pac J
May 17, 2020 10:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
