Help with noise from front of engine
Old Mar 17, 2005 | 08:21 PM
kidcamarosc's Avatar
Im getting this weird noise coming from the front of my new 350. The noise sounds like its coming from the balancer area. I put a new balancer on but the noise is still there even with my belt off. It almost sounds like a pulley whine or the way my smog pump sounded when it took a dump. There is only maybe a half hour runtime on the motor. I hope its not something internal. No visible shavings after first oil change but there was some black soot or something that was at the bottom of my drain pan after draining the oil.
Old Mar 17, 2005 | 08:46 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
does it have a gear drive or chain?
Old Mar 17, 2005 | 08:54 PM
chain. That was another thing I thought about but wouldn't that be more of a slapping noise.
Old Mar 17, 2005 | 09:07 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
it could be the chain or cam gear rubbing on the block/cover if the cam walks to much.
Old Mar 17, 2005 | 09:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Take a chunk of heater hose, like a 2' section and probe around using it like a stethoscope. Try to determine the origin of the sound.
Old Mar 17, 2005 | 09:23 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
If it's a double row timing chain on a 1-piece rear main seal roller block, it's probably hitting. It will hit at the top of the chain by the oil galley plugs.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
