Please help again.
Old Jul 17, 2001 | 07:01 AM
JJ IROC's Avatar
Please help again.
Ok guys from my last post I was having trouble with my car feeling like it was hitting a rev limiter at about 3500 and then going to 4500 and basically wont rev past that. Found here https://www.thirdgen.org/messgboard/...L/011281.html. I borrowed a more accurate fuel pressure gauge from a friend of mine and at idle the fuel pressure sits at about 45 psi. Then when I hit the gas it goes up as high as 70-80 psi. do you think that might be the problem and what might I do to fix it. The adjustable fuel pressure regulator is new. Thanks.
JJ IROC
1987 Camaro IROC Z-28 383ci. TPI 6 Speed T-56 black
My Car
jjiroc@alijas.net
Old Jul 17, 2001 | 08:40 PM
Guest
Guest
Posts: n/a
Sounds like the problem to me, 70psi is WAY too much.
Sounds like your new regulator is junk.
Old Jul 17, 2001 | 08:42 PM
Guest
Guest
Posts: n/a
NZKnight
Oct 15, 2015 02:47 PM
88CamZ
Oct 8, 2015 10:29 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
FormulaEngland
Sep 30, 2015 01:50 PM
