TPI windage tray - did they come with them?
Old Jul 17, 2001 | 12:30 PM
RW91B4C's Avatar
I'm putting my 383 together, and will dyno the engine with a carb just to see what kind of power it will make and to be sure there are no problems, before I yank the 305. The guy at the machine shop told me the a tpi should have a stock windage tray already. Is this true? If it is I'll just take the one off the 305 and put it on the 383 before it goes in. If not I would like to get an aftermarket one before the dyno. I'm trying to get all the power I can, its a daily driver, so I want a tray! Thanks
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old Jul 17, 2001 | 01:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I don't think they do, but I could easily be wrong. I've never seen one that comes with one at least.
To put an aftermarket one in, you have to use an oil pan that can accomodate it. It can't have the part of the baffle in front of the sump that functions sort of as a windage tray. It has to be empty.
I have the old 6-quart Z28 pan on my 400 with a Moroso tray on GM studs, works great. Of course that whole setup is for LH dipstick into the block. I modified it by installing a dipstick "hole" from a big block pan, and using the gauge & tube assembly for a 78 El Camino. I think there are some aftermarket pans available for the RH dipstick system that will accomodate a tray.
ICON Motorsports
Old Jul 17, 2001 | 02:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you talking about the oil splash shield under the intake manifold, or what is commonly referred to as a windage tray at the oil pan like RB is talking about?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 17, 2001 | 03:24 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Im about 99% sure the answer is No, Reig
The oil windage tray is found in higher end cars like vetts. The 1% that im unsure about is the TPI 350's, They might have come with a factory windage try but probably no on the 305.
SSC
Old Jul 17, 2001 | 08:53 PM
Guest
Guest
Posts: n/a
Its not on 350's either.
stalkier
Dec 6, 2015 11:25 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
