Stroker motor parts opinions....
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Decided im going with a 383 LT1 and found some parts i've decided on getting and would like opinions on the ones i've got chosen so far:
http://www.cnc-motorsports.com/product.asp?ProdID=7667
http://www.cnc-motorsports.com/product.asp?ProdID=2136
http://www.cnc-motorsports.com/produ...3&OGroup0=3672
Gonna be a 383 roller engine with a cam with the following specs:
112 LSA 230/244 .510/.540 on 1.5 rockers (i'll be running 1.6, rougly at .540/.570)
Compression ratio of 11:1.
Ported heads with roughly 260cfm flow at the intake at .550 lift 190 cfm at the exhaust @ .550.
Basically looking at peak power around 6100rpm. Will this bottom end hold up to 6200-6300 shifts? Looking to put out about 380-390 rwhp. Only going to the track once per season, so basically 4 times a year. other than that, gonna be a cruiser. Will the bottom end hold up for what I need?
1992 Trans Am
May 10, 2023 07:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
