Part Identification
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Part Identification
Whats the name of this part? Broke it while putting in the Temperature sensor. The part I'm speaking of is the one down in the intake manifold with the silver plunger sticking up. It has a lot to do with smog and vacuum, I know that, but I need to know what to tell the parts guy.
Car: 88 Camaro
Engine: L98 350
I'll guess. It's a temp sensor, the early engines had three or four separate ones. What color wire went to it? Could be a cold start injector control.
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Did it have a bunch of vacuum lines running too it? Might be the EFE valve. Good chance there is a part # on the piece you broke off or the piece stuck in the intake.
Here's a pix of what broke off of it. It must be a thermo vacuum switch of some kind.
LT1Formula
20
Nov 14, 2015 12:02 AM
