Will these rockers work and are they any good??
Old Jul 16, 2001 | 09:52 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I was thinking about getting the Blazer Aluminum Roller Rockers that are 1.5 ratio for 3/8 stud. I don't need self aligning because my AFR heads have guideplates, but will I have problems with the centerbolt valve covers?? Also does anyone have an opinion on the quality of these rockers??
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Jul 17, 2001 | 11:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would not recommend aluminum rockers for the street. They have a nasty habit of fatiguing and breaking in half unexpectedly when they get a few miles on them.
As long as your valve springs and other parts will support it, go for as much lift as you can get. Use 1.6s. A large-inch motor needs as much flow as you can give it.
I'd recommend the Comp steel rollers, IIRC the # is 1302.
ICON Motorsports
Old Jul 17, 2001 | 05:57 PM
ede's Avatar
ede
i like the steel rockers from comp with the needle bearings and roller tip
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 17, 2001 | 06:10 PM
irocbsa's Avatar
I'm using Crane Gold 1.5s.
bsa
Old Jul 17, 2001 | 09:10 PM
Guest
Guest
Posts: n/a
I'll third the comp rollers, just in case you needed another opinion.
Old Jul 18, 2001 | 09:04 PM
Car: 89 IROC-Z
Engine: 383
Which steel Comp rockers do you use?? Which ones can I use that aren't self aligning but will still work with centerbolt heads?
specialized
Jun 18, 2022 09:26 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
midge54
Dec 27, 2019 04:14 PM
justin57
Aug 20, 2015 07:05 PM
milk
Aug 10, 2015 06:26 PM
