Guys... need help!
Old Jul 17, 2001 | 08:40 PM
B L A D E's Avatar
Guys... need help!
I have an 89 5.7L TPI... I noticed something the other day, smoke will come out of my PCV grommet if I pull the vaqlve out, not a little bit, like normal, but not alot either, just more than average. Its worrying me... what can I do to figure it out and fix it??? Thanks... Any questions, just ask.
Tris
Old Jul 17, 2001 | 09:27 PM
Guest
Guest
Posts: n/a
Oil level low
Engine temperature high
Too much blowby
Pick one.
Its probably fine.
Old Jul 18, 2001 | 05:17 PM
B L A D E's Avatar
Ummm.... about that engine temp thing... my car is forever sitting at 220*.... and the blowby, if that IS it, I would assume there is no way to fix it except for a rebuild, right???
Tris
Old Jul 19, 2001 | 01:05 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
See whether your engine fan is coming on properly. Sometimes they burn out or the wire frays or ...
I would take it in and get an engine coolant flush done, just in case some of the passages are corroded up.
If all that is fine, then get an extra fan put on the rad, maybe on the front this time, and have it wired to kick in with the other one. This should fix the problem.
1986 Camaro Sports Coupe
T-tops, power hatch, third brake light
LG4 305 V8, "Damonized" Q-Jet 4bbl, K&N filter
Crane ignition kit, TH700R4 transmission and Derale cooler
Air conditioning, pw, pl, pb, ps, tilt wheel
Kenwood cassette, Pioneer 6x4 component front speakers
Rockford Fosgate 6x9 Punch rear speakers
Aluminum slots and Goodyear 225x60R15 Eagle HP tires
Old Jul 19, 2001 | 03:37 PM
B L A D E's Avatar
The temp still doesn't explain why this much exhaust gas is getting into my crankcase, and pressurizing it!!! Please help!
Street Lethal
Sep 7, 2015 01:09 PM
jharrison5
Aug 19, 2015 05:53 PM
Street Lethal
Aug 14, 2015 08:25 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
87CamaroLT
Apr 27, 2001 06:18 PM
